View the port egress CoS queue statistics. The system displays the statistics of the forwarded packets and bytes, and the dropped packets and bytes.
If you disable rate limiting on queue 6, bandwidth is shared based on the weights from queues 0 through 6. Based on equal weights assigned for queues 4 through 6, equal amounts of traffic egress queues 4 through 6. The system displays Queue 6 to provide much lower throughput than 50% of port bandwidth.
If there is egress congestion when you enable the boot config flags flow-control-mode command, then the system does not drop the packets at egress, and does not increment the counters under the show qos cosq-stats interface {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} command output. Instead, the system drops the packets at the ingress port and the system counts them under the INDISCARD column of show interfaces gigabitEthernet error {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} command output.
Use the data in the following table to use the show qos cosq-stats interface <PT_PORT> command.
Variable |
Value |
<PT_PORT> |
PT indicates the slot number; PORT indicates the port number. |
